I know that a sold axle is stronger but beyond that what is better than the stock TTB. And If I we're to look into a SAS is there anything that I must do do make it work properly. Meaning more stuff to buy or modify. I ask this because my brother offered me a solid axle off his truck but he didn't know when he would get it off. I have a person that can sell me drop brackets for my TTB. But I was just wondering if a SAS would mean a lot of work, and if so are the benefits really worth more money? I have a 1991 Ranger and I'm not sure what axle my brother has.
It actually depends on which particular axles you are comparing whether a solid axle is stronger or not.
Pretty much anything out there would be stronger than a Dana28.
It's different with the Dana35 though, some axles might be a slight bit stronger (Dana44 from a F-150), some are massively stronger (Dana60 from F-350), others are weaker (Dana30 from a Jeep).
Some common axles from weakest to strongest:
D28 (TTB) (weak, belongs on a golf cart or ATV/UTV)
D30 (solid) (approx. 5-30% stronger than D28)
D35 (TTB) (approx. 5-25% stronger than D30)
D44 (solid or TTB) (varies from 20% weaker to 5% stronger than D35)
D60 (solid) (approx. 30-60% stronger than D44)
(% ranges are due to variations over the years, such as an axle having different size/grade u-joints)
All 1991 RBVs produced came with the D35 front axle. IMO, an axle swap won't yield a whole lot in the way of strength unless you were to use a D60, which for probably a majority of uses is just plain overkill.
Your D35 front axle will easily support up to a 35" diameter tire (37" if you treat it nice) with only a few minor upgrades thrown at it (locking hubs & u-joints primarily).
Some people however do the SAS simply because they can better understand the workings of a solid axle suspension better than a TTB suspension. This doesn't necessarily make it better than the other, both do have some distinct advantages.
I would take a look around the site here, both here in the forums, and in the Tech Library, there is an overwhelming amount of info when it comes to comparing, upgrading, and swapping of the various axles (don't forget there is the Search box at the top, and the Search function within the forum itself, too). Many items are stickied (some as "Announcements") at the top of the Axles, Steering, 4WD Suspensions, and Xtreme Suspension forums, and will have various links that will take you to more info.
Hope that helps.
