trans modulator adjustment?
Brutal6
10+ Year Member
In order to FIRM up the shifts which way (in/out) should the allen head screw be turned at the trans vacuum modulator? A4LD.
Thanks,
Brutal6
turn the screw in to firm up shifts i think
where exactly is this, i'd like to give it a shot for myself
on the passenger side of the trans under a heat shield most of the time
87 auto , no od
what controls the OD shifting on 87 auto tranny? mine shifts fine 1 2 3, then 3rd lockup, but never goes into OD. any thoughts?
Jammed shift spring or misadjusted or stretched TV cable. That'd be my first guess. anything else I can think of would cause problems in other gears as well.
