Carbs have many advatages over EFI....espically on the trail.
If you lose a componet on the EFI system and it runs like shit....whats the chanses Vice grip and a screwdriver will fix it?
You ose a fuel pump on an EFI, your screwed. On a carb a big piece of rubber hose and a 5 gal can strapped to the roof will get you home.
You roll your vehicle over. A carb will stall before the engine has a chance to drain all the oil from the crankcase to other parts of the engine. EFI will keep it running while it beats the hell out of your mains and rods, and every other componet on the bottom end.
EFI is good for the soccor moms minivan. BUt in a real truck drivin by a real man who wants real performance and the satisfaction knowing that he can tune it himself, carbs are the way to go.
Besides, you can tune, setup, and fix carbs a helluva lot cheaper then EFI.
The 2150 motorcraft carb isnt the best powerwise (there only rated at 335CFM or somewhere thereabouts), but there probely one of the best on angles.
Holley makes a Hi-Po 500CFM 2bbl that will bolt right to any 2bbl ford manifold. Based off the design of the 2150.
later,
Dustin
