- Apr 13, 2009
- '06, '11
- 3.0 V6
I've been really impressed with the 3.0 in my 2011 Escape. I'm not sure how it compares to a Ranger tho.
On more recent vehicles the engine and transmission have their own serial numbers independent of vehicle VIN, which is not referenced on the engine. I worked for Mazda in its reman facility and this was the practice. Only the factory could confirm which serial number engine and transmission went into a particular VIN, and for a long time Mazda wasn't recording that info in Hiroshima or, if it was, wasn't releasing it. My Japanese boss discovered this when I raised the question about whether we could track VINs that way. He was scratching his head about that too.I know there’s a number that tells you the year I think of the block. It’s towards the back of the block on the drivers side I think.
I understand the desire for matching numbers on something collectible, but fortunately or unfortunately, depending on your take of it, Rangers haven’t really become collectible except to us enthusiasts. The Bronco II is supposed to be on the way up in collectible status and I’m not entirely sure how I feel about that.
Back to the OP, I am as concerned about the wiring damage as I would be about the engine. Having access to another similar Ranger would allow you to see exactly what was burned/damaged. You'll have to get that right for the engine to run. Also check the engine computer, as it could have been damaged or fried.
Yea 73 this year. Because of where it burnt, top of the eng, I was told they put in new wires however looking at this it appears the wires were plug wires. I can see a bundle that looked burnt and the elect box under the hood has been pulled up so as to track wires. If i had the space i would try to find an old Ranger that was up for sale as a parts truck. In the old days, 60's to 70's the wires were ether to the coil or starter or ignition. Now who knows where it all goes.
The small wire is from your ignition switch. It should provide power only when the key is in the run position. This tells the fender relay (solenoid) to pass power from the battery to the starter.ok so as you can see by the hood about where it burnt. I think they replaced the intake and pulled & swapped one of the heads. Also if you look at the starter solenoid one wire is off and when you put it on and turn the key to on, the starter cranks. nothing when disconnected. Chasing wires is a long process but i have time now so.....?
