Quasimo1
Hi Everyone. I have a 1995 Ford Ranger with the 3L, that has a crank no start condition (no spark). I have performed the following tests so far.
* Verified the crankshaft position sensor is sending out a signal via a waveform test.
* I have verified the 3-wire camshaft position sensor is receiving voltage via a test light and verified there is a good ground. I have attempted to test the camshaft position sensor signal wire with a multi-meter and have observed very low voltage <1 volt with key on engine off. When I attempt to crank the truck the voltage jumps all over the place going as high as 7 volts.
* I have verified that the coil pack is receiving 12 volts and primary resistance is within speck.
Any idea on how to further troubleshoot the no spark condition?
-Edited to correct the model year.
