- Sep 12, 2023
- Montana
- 2.9 V6
- Total Lift
- Stock
- Total Drop
- Stock
- Tire Size
- Stock
I acquired an 87 2.9 which had been sitting. Replaced FP relay, in tank pump (in rear tank) and main pump. Key on, both pumps run, Engine will run for a second then die and further cranking gives me nothing. When I depress the Schrader valve on the fuel rail, I get lots of air along with aerated fuel, figured air in system. been bleeding it off and on for 2 days, still getting air in rail. pulled line to regulator, no fuel leaking out. I'm probably gonna replace the reg anyway. I let it sit for a minute and crank, fires for a sec then nothing. I thought maybe I'm bleeding off air from when I had the lines disconnected to main pump and transfer switch, but seems it should have cleared up by now. Ideas?
