Hello everyone! I'm new here, though I've been poking around the site for several months now.
I bought a '97 (correction: ‘96) Mazda B3000 back in April. I love the truck but I guess I did a terrible job vetting it. Here are a few highlights:
- The head gasket had failed and someone used head gasket sealer before my dumb ass bought it... now the heads are warped
- Oil leaks from just about everywhere other than through the block itself
- The headliner looks like someone threw a stray cat in there then set off a firecracker (I knew about this one of course, but I think it's funny regardless)
- The driver side of the engine wasn't even attached to the engine mount
I'm quitecheap resourceful so I am fixing as much as I can. I got the engine out of the truck today and confirmed that one of the engine mount bracket bolt holes is broken off the block. I also learned that a second bolt hole is also broken, though I have no idea what it's supposed to be attached to.
My two questions:
1. Is it feasible to repair these without replacing the engine block, or is there a way to mount the engine securely without that particular hole?
2. The broken bolt hole on the left is for the engine mount bracket, but what bolts into the broken bolt hole on the right?
I need to purchase some replacement heads already, so depending on how much of a problem these bolt holes are it might be worth it to just replace the whole motor.
I'm quite
My two questions:
