Eddo Rogue
- May 18, 2020
- Burbank,CA
- 4.0 V6
- Total Lift
- skyjacker front leveling kit
- Tire Size
- 31-10.50R15
- My credo
- Crossed threads are tight threads.
Hey all,
I am dreading doing the radius arm bushings , and was wondering if instead of taking everything apart at the knuckle end, I could just grind out the rivets on the bushing bracket and pull it off the frame to swap the bushing, and then just replace the rivets with bolts after?
Also if you would like to suggest rubber vs polyurethane I am still torn on this decision as well. Leaning towards poly...
Cheers-Eddo
Cheers-Eddo
