Update: I tested the e-brake and the wire does move back and forth as it's engaged, so that's good.
Yes, that's very good.
Ran to the store to get a torch, more PB Blaster, and a sledge.
That's even better!
I am starting to get a little movement in the self adjuster in the back, as I'm looking at it from the backing plate, which way should I be turning it to loosen the shoes? I don't want to tighten them further. this part is solved: have to move it upward
Tighten, you'll feel it "bottom". Once it's good and loose, it'll feel "rattle-ley" through your spoon or flat blade screwdriver. I tried memorizing "up or down" for "loose and tight" for years, but gave up. It's simply a design feature by Ford Engineering to drive us to drink.
- I should be hammering the front face of the drum around the studs, correct?
I've had the best luck hammering the outside edge... like where your tape measure is hooked.
Exactly. Beat on the drum where it's the strongest. You're wanting to "shock" the parts, to break the rust bond.
Don't be shy about it... give it the full rage.
Sage advice, from one who Knows The Way Of The Jedi..
don't pry on the backing plate, can't get new ones.
if it moves at all cut those pins now.
Yes, ABSOLUTELY. DON'T BOOGER YOUR BACKING PLATES. Those, and your axle flanges, are the only parts that matter at this point.
Yes. Get something under the flat head, Pull them outward, and cut that sucker off. A flat blade screwdriver, a panel popper tool, or anything (hell, even a table fork) that that will let you get it pulled back enough to get that head off of the backing plate, and get a good pair of side cutters under it. A man-sized pair of side cutters will do the trick. Just don't booger your backing plates.
You're close.
If you can, let it sit overnight and let the penetrating oil work its magic.
A lot of times, I'll hit a brick wall, sleep on it, and then beat it's ass when fresher in the morning.
