newnthused
I bought the truck with the parking brake disconnected and the parking brake pedal fully depressed. So I released the pedal today and pulled it hard to connect it.
Now, when the pedal is fully depressed, the cable is tight, but the parking brake doesn't feel engaged. The truck still rolls with transmission in neutral.
Also, when I pull the pedal release (which isn't even there, just the mechanism behind it that I have to reach for to get), the pedal does not fully release. I have to manually pull the pedal up to what I assume is the "full-off" position (it being fully up and away from the floor).
I tried to adjust the equalizer nut (with no success because it was stuck), but didn't mess around with it too much because the Haynes repair manual says to "adjust the rear brakes prior to adjusting the parking brake cable," but then doesn't refer to the section that instructs how to adjust the rear brakes. I don't want to accidentally mess something up chasing the wrong issue.
I'll include a picture of where I reconnected the cables today.
