sgtsandman
Aircraft Fuel Tank Diver
⭐Supporting Member
TRS 25th Anniversary
- Mar 11, 2017
- Aliquippa
- State - Country
- PA - USA
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 2.3 EcoBoost
- Tire Size
- 265/70R17
- My credo
- Anything that can go wrong, will go wrong. Plan for it as best you can.
How old are your O2 sensors and have you looked at your MAF sensor? O2 sensors wear out over time and if they are the OGs, they are due for a change (mine are due as well). If the Mass Air Flow sensor is dirty, it will effect fuel trims as well.
As mentioned above, the winter fuel will cause a drop in mpg and the longer time it takes to warm up to operating temperature will do the same. Up until the engine reaches a certain temperature, the fuel trim will be running rich to speed up the warm up time.
Check your tires too. Every 10 degrees of temperature change equals 1 psi of tire pressure change, plus tires lose air pressure over time anyway. Even new tires on new rims.
