O No 3.0!
Looking for the big rear bar on the mid 80s 2wd bronco ll's.
Perhaps. That bar is bent in the right way, but there are 2 different thicknesses. The bar I would need is 7/8" or 1" thick. The other bar is smaller and not much different than what is already on my Ranger.This is an 85 BR11 4 X 4 . Is this what your looking for?
Measured all , 2 88 s , 90 , 85 and 86. All 3/4 .
It would be stiffer than a Ranger bar. Someone said a Mazda is a bit bigger too.Man.. my 96 could probably use one of those..
Yup, I'm sure I would love one, but it's just a little rich for me...at least right now. Also that Hellwig is mounted just behind the differential. I could do the very same with a bar from an Exploder. I do actually have one I've pulled and got on the cheap.@Lefty i see that there's some 7/8" rear bar kits available on ebay from Hellwig.. bar, brackets, end links and hardware for 390$ shipped to your front porch..
Not as cheap as junkyard diving.. no. But a whole lot easier, brand new, and it'll be on your front porch in 3 days!
My truck doesn't have a rear bar at all actually.. but my plans for the truck do call for one.
On the brakes, i recommend the power stop kits from ebay. I have the drilled/slotted fronts on my 97 with the good pads. They have been great for over 2 years, most of that with no rear brakes at all due to a blown wheel cylinder that i haven't fixed because im going with mustang rear disc soon. I am also upgrading the front to the sport trac rotors & new power stop calipers & brackets. Just need to buy the braided hoses now.Yup, I'm sure I would love one, but it's just a little rich for me...at least right now. Also that Hellwig is mounted just behind the differential. I could do the very same with a bar from an Exploder. I do actually have one I've pulled and got on the cheap.
My next project is a set of Ching-Chong slotted and cross drilled rotors for the front end and a regular brake job for the drums in back. I want to stop a little faster just for safety's sake. That's a bigger priority.
Those leaf spring clamps have already made a very big difference back there. If you haven't done so, try them. I'm not even sure if a nice bar will improve upon them. So I will just wait.
And yes, I waited for over a year looking for a decent junk differential then gave up and bought a new one anyway.
