No, scratch that. Here’s a couple ideas.
One. I grabbed one of the small stretchy nets out of a Ranger extended cab in the salvage yard and put a couple S hooks on the corners, little ones. Sometimes I clip it to the inside of the tailgate, top and bottom, close the gate, and I can put all kinds of smaller crap in there.
Two. Think of the same concept, but lift up your toolbox, and make a couple of rope loops under the bolts that hold it down. Then you can use bungee cords in front of the toolbox (actually behind the toolbox) for whatever.
Three. I think I got it at Harbor freight, but I basically bought a net that’s about 3‘ x 5‘ stretched that’s made out of bungee cord rope, that has four or five or six hooks on it. I don’t use it a lot, but when I need it, it’s invaluable. It would work great with
@RobbieD ’s bed eyes.
four. I also keep one or two milk crates/vegetable crates in the back of the ‘87 Missing Linc, sometimes tied down, sometimes not. I can put a whole bunch of smaller things in there and even if the crate slides a little bit, it doesn’t make a racket or damage anything.
Five. When I first got my 97, the 87 had an aluminum cap on it, and almost the full side glass opened on both sides. It also had a lightweight ladder rack on the front and back frames. You can pick them up for 250 bucks and paint them with $10 worth of Rustoleum and they look like new. I’ll never use mine again, and it’s sitting in the yard if you want it.
Six. I saw this at the 40th. A guy just had a piece of heavy indoor outdoor type of carpet in his bed. He used fender washers and screwed through the carpet into two by twos across the bed. He could roll it up and put it under the toolbox, but when he rolled it out, it would hold everything in place.
Seven. If you have a sliding back window, you could get a cute chick to come with you, and when you buy something, she could hang out the window and hold it, so it doesn’t slide around. Also makes for a nice view in the rearview mirror.
Seven amendment. Scratch number seven.
Seven replacement. A long time ago I got four or six plastic dock cleats, real little ones. I cut a small piece of oak and drilled through the overhang of the bed side to hold them in place behind the bed lip. Then I screwed the cleats on them hanging upside down. Actually, the reverse order. The only make a few tiny holes, and they will hold the titanic, and you don’t see them, and you can take them out when you don’t want them.
It’s not real practical, and it can be very expensive. (especially if you’re married.) but I think the original number seven is my favorite.
Hope it helps, hope you got a sense of humor…
