2.8l V6 Mechanical Fuel Pump - Open Chamber on bottom?
halfmoontrail
Florida 32666
Hi,
I'm finishing up my Duraspark conversion on my 85 B2. She starts on fuel poured into carb, but isn't getting fuel to the carb. I bought a new fuel pump from one of the chain stores, and I was surprised that the chamber on the bottom is open, you can look in and see the spring. Some other pictures online seem to show a metal plate over this area. Is it correct to assume the following:
1. My old fuel pump will have this plate and I pry it out?
2. I'll pack this chamber with grease and knock the plate from the old pump into it?
OR, it's fine to run it open?
OR, do I return the one without the cover and buy one with?
Many thanks, Steve
Got a pic? I’m having a hard time visualizing it. It should have an opening between the bolt holes for the rod that drives the pump to go in.
I don't have a picture of my new one as I'm at work, but it's the black rectangular area shown at the right bottom of this picture. This one appears filled/blocked/capped whereas my new one lets you peer into the area and see the spring within.
This is what I was talking about, I'm taking this one back today and I have already ordered one like the one shown above. I still don't know how this opening is addressed on factory units - is it a metal or rubber cap, or some material that is cast in place?
No es bueno.
It’s covered with a steel plate, staked in place.
