Nelson and Hudson
- Jul 8, 2020
- Redondo Beach
- 2.9 V6
Hello, I've been trying to track down this problem for ages so hopefully someone can offer some advice. (1987 Ford Bronco II, 2.9L V6)
When driving around at low speeds, the engine will just randomly shutoff with no warning and then flash the "emiss" light. I can catch it if I'm quick enough by turning the key, which will give it a boost of power and it'll continue to run for a while. Doesn't matter if it's cold or hot. After driving around for a while and pulling into a parking spot, the engine will die. Doesn't happen on freeway speed and it runs and idles really well.
I replaced: Fuel filter, oil filter, new oil, alternator, starter relay to starter cable, ignition coil + connector, distributor and cap, wires, ignition switch, plugs gapped, new battery, cleaned the IAC
