MarcosLopez77
- Feb 21, 2013
1991
Not sure if i posted this in the wrong area but im looking for any suggestions on a really bad vibration on my truck
1991 Ford Ranger
Extended Cab
4x4
maual transmission
Ive owned this truck almost 30 years now and has developed a really bad vibration at speeds in excess of 65mph. Ive done the following in the last few years or so but the vibration still remains
-new tires
-new shocks
-new bearings (front)
-new ball joints
-new u-joints
-balance all tires
-new tie rods
-new sway bar bushings & links
-new radius arm bushings
-new clutch
-new slave cylinder
-new carrier bearing
-new steering gear
-replaced steering shaft (used)
-alignment
-new pads and rotors
im not really sure what else to check
-front axle ujoints?
-out of balance drive shaft?
*also i noticed if i put the truck in neutral while travelling at 65mph or higher the vibration remains. This leads me to think the vibration is not coming from the driveline but i may be wrong
any suggestions are greatly appreciated
1991 Ford Ranger
Extended Cab
4x4
maual transmission
-new tires
-new shocks
-new ball joints
-new u-joints
-balance all tires
-new tie rods
-new clutch
-new slave cylinder
-new steering gear
-alignment
