Hello, TRS. I have a 2005 4x4 4.0 V6 Ranger with 167K miles, and I'm hoping someone can help me out with the 4x4. The 4wd selector switch is illuminated, but flipping it to 4Hi or 4Lo does nothing - there is no click or indicator light on the dash and 4wd does not engage. I tested the voltage on the switch and get about 4V at 2Hi, 3V at 4Hi, and 2V at 4Lo. The fuses all are fine.
I was thinking the transfer case control module was bad, but with ignition, the 4Low and 4x4 dash indicator lights do briefly flash one time, and then turn off. If the module was bad, would it be able to send those signals?
When I bought this truck, it didn't have a front driveshaft at all so I installed one from a scrap yard. This truck has pretty janky wiring in some areas (previous owners), and a mechanic working on an unrelated issue said he noticed that two of the wires on the transfer case were connected incorrectly (not sure which ones). He repaired the connection but the 4wd still didn't work. One of the 4wd fuses was blown at the time, and was replaced. (I'm not sure which one either...)
Do you think this is a transfer case control module issue, or does it sound like a wiring problem?
Thanks for any tips. Have a great day.
