- May 23, 2019
- 2.3 (4 Cylinder)
- Tire Size
- 15"
OK, sorry everyone, I inadvertently started a bit of a firestorm. I thought that the '85 2.8s all had the same cooling system configuration and @AndyB. has proven otherwise. Let me do my best to provide more info and I'll post some pics ASAP.
In AndyB's post, with the three images from the shop manual, the middle image shows my set-up (albeit without much detail).
His image of the V6 on the engine stand (nice work Andy!) shows it even better WITH THE EXCEPTION that my intake manifold water neck does not have a t-stat (like an early Mustang 289/302 does).
I may have created some confusion (my bad) thru ignorance; my water neck has the coolant gauge sending unit and the electric fan sending unit (the switch to complete the circuit to turn the fan on). It does not have a t-stat to regulate the passage of coolant.
Per AndyB's post with the two t-stats; it's distinctly possible I bought the wrong t-stat (ignorance again). I have a Motorrad MOT 234-192 (Rock Auto) based on my receipts:
Rock Auto does not stipulate the location of the t-stat in their listings.
