corerftech
My sons 130k mile 2011 2.3l is now on clutch #3 (as far as I can tell)
Replaced in February, it has nearing 10000 miles on Perfection self adj clutch/Sachs solid flywheel/perfection TO, slave, master.
Truck acquired at 119,000
Clutch was iffy then.
Made it about 3500 miles and it was toast.
Replaced the whole system (I had just done a 1990 with same gear and stunning performance of parts for many many miles).
When finished, clutch activates in first 1.5 inch of travel.
Very difficult to drive for a 6'2" man in a single cab, SB truck.
When we bought the truck for son, clutch behaved same way.
Son drove to Ohio this month and back to TN, upon arriving home stopped at grocery. Came out and had clutch slip and 3000 rpm for 2 miles to get home. Parked, sat for two days, test drove just fine.
I drove it, found the pedal now releasing at 1 inch or less of travel. Have to use a socked foot to drive and tap my toe, literally. I may be way off with an inch and maybe its a half inch.
I have eamiled perfections group but I am not likely to get a reply.
Since this is now the total of an "OE FOMOCO clutch" and then an "autozone" replacement by last owner (first owner actually and maybe they fed it TWO plates!) and then my "perfection" replacement, I am questioning the geometry Ford left the drivetrain with. Did they overcut the bellhousing face? Undercut the bosses that the TO bearing mounts to???
I am afraid with the long Ohio trip, the drivetrain elongated a few thou and closed up the mismachined narrow clutch stack causing the slip he experienced for 2 miles on way home.
I drove today, beat on the truck. 6500 rpm shifts 1-2, 2-3, 4000 rpm clutch dumps in first, no slip. Absolute perfect behavior, except if a gnat lands on the pedal, its out of gear!!
Anybody???? Any insight???
I am about to consider adding .030/.040 as as shim to move the bellhousing away from engine. That will compromise the starter gear by the same but the starter is far less sensitive than the TO bearing. .030 doesnt seem like much but I think it will affect the geometry greatly. Im about to add a big fat air bubble to the darned hydraulics just so the clutch WONT MOVE! (not really).
Help!
Mike
Help!
Mike
