MOVE TO FREE section -Last chance! Ranger front suspension parts
laser3kw
(actual join date:2001) Rockford, Il
June 1 - parts left here via garbage truck :cry::cry:
Moved to free section
Last chance! If it's here May 1, it goes in the scrap!
I need it gone - hate to see it wasted
Listed are parts that were for a 1999 Ford Ranger, 2wd, coil spring front suspension
your research may find other years they fit. Quick search on Car-parts suggest they may fit 1995 - 2011- you must verify
Parts came off a low mile southern truck and have been in storage for 17 years.
(2) lower A-arm
(2) upper A-arm, press in ball joint type (old ones removed)
(2) springs, #5310-AA, not collapsed. Approximately 4"id x 16.00"" x .740" diameter.
all components are used, any bushings or ball joints should be inspected before use and replaced as needed
_____$100_____ or reasonable offer
can meet a TRS member in North central Illinois at a reasonable distance
70415
70416
70417
70418
70419
I thought torsion bar meant it didn't have coil springs?
Are you willing to part out the upper arms?
Moved to the parts for FREE forum per your request....
