Tikker
- Jun 25, 2010
- Acworth, Ga
- 2.3 (4 Cylinder)
@Tikker: One last question for you - does your B2300 have torsion bars or coil spring for front axle?
Yes, it has the 2003 coil spring setup. I had figured I would use a coil spring set up on the axle like it came from the late model Cherokee and have a shop cut out as much of the IFS material and brace the engine area to support it, OR have it lifted enough to clear the what's there. The only thing that had me worried was the frame size, I think I recall reading the 2wd frame is a bit narrower than the 4wd/Edge models, so space for a transfer case would possibly make for a tighter fit, unless I spent some big money on an Atlas. But an Atlas case seemed overkill for a 2.3l Duratec & the tire size that I planned to run with no plans to use as a rock crawler.
