Scannell
- Apr 25, 2021
- Michigan
- 2.3 (4 Cylinder)
I have a 2001 with the 2.3L Duratec that is overheating and I am stumped at finding the cause. It mostly overheats when running highway speeds but if I run it around town long enough the temperature will start to climb.
I have no coolant leaks and there is no coolant in the oil. When I pressure tested the system and it tests perfectly. The radiator has been flushed out with a hose and seems to have good flow. The front of the radiator was also cleaned of any blockage. I took apart the water pump and everything looks and works as it should. The fan clutch will turn easily by hand but has enough resistance to not spin. I replaced the thermostat with a mechanical Motorcraft version for a 2005 ranger and that little effect other than taking a little longer to overheat. The system has been bled per the workshop manual instructions twice. I am stumped, is there something that I am missing?
Background:
This started when I had a crack in my degas bottle that was leaking when pressurized. I replaced it with an aftermarket one and couldn’t get it to seal properly so broke down and purchased a Ford replacement part. A couple months ago I also had the cylinder head off to repair a valve that wouldn’t seal properly and replaced both of the cooling system gaskets and the hose while I had it off. I did not notice any heating issues at that time.
Background:
