CB Radio Installation Help Please
Garageguy60
Forum Member
Pa.
Good morning everyone. I was wanting to hook up my cb radio in my 2004 Ford Ranger XLT Extended Cab. I wanted to know where to exactly hook up the power wire to (thinking fuse panel) and best place for the ground wire, also where did you guys mount your cb radio's at ? Any info. and pics. on this subject would be appreciated .
How you power your CB depends on how you use it. I have mine wired directly to the power, that way I don't have to use the key when I use it. As far as mounting it, I have mine above the rear view mirror. Heres a picture.
I hit the picture button twice, must be age related.
I agree with "shadowrider", I would wire it fused strait from the battery but as I understand it, your truck has that cool power center under the hood with extra room for add on electronic systems, that could make for an extra clean installation though I would still prefer to leave the ignition switch/system out if the circuit.
I ran a power wire from the battery into the cab on its own 30 amp fuse to a 4 pole "Rig Runner" under the dash. Initially it was setup that way so I could install a couple of other Amateur Radios and a GMRS radio, but I just have the 1 Ham Radio installed right now, got rid of the CB a long time ago, nobody uses them things anymore for the most part unless you are in small groups, many just use GMRS or FRS radios of one type or another for group use. My CB I think I'm going to put back in because its nice to be able to hear truckers and communicate with them but for the most part nobody else uses them it seems anymore. I need to replace my Amateur radio and going to be relocating it so my CB is going where it was, and my Amateur radio I think I'm going to mount to the console I think it got too hot sitting down low on the dash and fried the speaker output as I have no audio from the radio anymore, of course it doesn't help that its a cheap Chinesium radio but still.
For your use with just a single radio, they only require maybe a 10 amp fuse, so just run a power wire direct from the battery with a fuse at the battery, then into the cab to wherever you want to put the radio. I'd stray away from wiring stuff into the fuse panel, its just easier to run a single power wire direct to your accessories.
Attached is what I installed for my radios. But in your case its overkill with only 1 radio. I did that with future radio additions in mind.
I have mine mounted to the driver side of the larger console on my 09 (it has the Pioneer sound package with the subwoofer). I wired it into the circuit breaker that powers my aux fuse panel I added under the dash. It is constant powered, so I know it could drain the battery if I left it on, but I always check it to make sure it is off. (I'll post a pic later)
I've left my CB on for 3-4 days a few times, didn't drain the battery, but they don't use much power either unless you are transmitting...but they still use less power than my quad band amateur radio which will pull 50 watts max depending on what power setting I have it set for, when I press that talk button. A CB will only do about 4 watts (legally).
If you have a digital cb you will lose your channel/squelch settings every time you turn the truck off if you have it hooked up to key power.
I had mine wired that way at the last trail ride, it was incredibly annoying.
I only did it because at the time it was easier to wire up, I have since expanded my "battery power" fuse panel under the hood so I have room to switch the CB over to that. It will be hooked up to the battery for the next trail ride. :icon_thumby:
Thanks alot Guys , alot of good info. really appreciate it. wildbill23c, where did you purchase that Ridgerunner 30 amp fuse panel at ? thats a good idea. im thinking of also getting and installing some time a Ham radio. whats the advantage/disadvantage of a Ham radio vs. a Amatuer radio ? i dont much about either one of those. just would like to have good back-up communication incase regular cell ever went down. also want to get a good home base unit. any recomendations guys ?? Thanks.
A CB radio is easier to use. To use a Ham radio, you are required to get a license though FCC. That requires studying a lot of information and passing a test put on by various Amateur Radio Clubs. Once passing the test, you will be issued a call number and should use that when using your radio. Ham radios transmit a lot farther than CBs and are much clearer.
Thanks 85ranger4x4 for your information on that fuse block, thats pretty neat. Thanks gw33gp for your information on CB and ham radio. I would like to study and find the info. so I can take the test and pass it. You cant have enough back ups, especially in this day and age.
GMRS radio is kind in between. It has better range than a CB but not as good as a HAM.
The GMRS license is more of a fee, give the govt $70 and they give you a license. I thought I heard it was supposed to drop to $30 at some point.
The HAM license isn't that difficult. I took it a few years ago. The local CERT (Community Emergency Response/Readiness Team) offered a 2 month? course. I'm sure you can find something like that in your area.
