Not quite right. The A/C is used to remove moisture when defrosting/defogger the windows.The ac compressor should only kick on when switch is on AC or Max AC .
You have it at the upper vent position, which will allow outside air in thru the upper vents.....no ac, just outside air, whatever it' temp is.
If thats what you want, you will have to rewire the controls to do that.It is my belief that AC, Max AC, and defrost should be the only spots it cycles the compressor. So ……. any suggestions on why mine isn't working correctly?
ive seen compressors blow holes in the sides because of sluggingwell hells bells, I never knew about "slugging"
2005 manual.
the PCM has the ultimate control of the AC clutch, it activates the AC relay.
