JimmyJamesH
I just swapped some wheels that had the same bolt pattern. The hub on the front wheels slid all the way through the center bore but the rear didnt. Is this unsafe to drive on?
My buddy got this 1994 Ranger project we'll work on after we finished installing the suspension and black rhino wheels on the current Silverado project and clear the garage. The Ranger needs a new set of wheels. Good to hear a spacer for the rear could help on the fitment.A 1-1/2” spacer would help, I bought a pair to space out wheels in my wheel horse but before I put them on I tried them on the ranger with the extra escape rims I have. Same bolt pattern but small center hole. They would work with the spacer. I paid around $80 for the pair of spacers through jegs.
View attachment 52304View attachment 52305
I don't like grinding on the center of wheels. For instance the wheel in the picture below. It has that raised lip around the hole where they punched it out and formed it. That gives a lot of strength to the wheel in that area and the area between the large hole and the lug nut holes. Grind it out and you lose that lip and the strength it provides.Jimmy,
It looks like you need to take the grinder to the hole in the wheel; it's the bolts that hold the wheel in place not the axle.
I took a set of 14" 1994 Ranger wheels in trade, needed to grind out each one to fit over the 1987 BII's front hubs ..)
View attachment 52296View attachment 52297
