Auxiliary Lighting- KC Pro6 question
Class5Cole
Mission Viejo, CA
I have a 2001 Ranger Edge. I'm attempting to run KC Highlight Pro 6 LED's off of the fog light circuit. (One light per harness). Two questions for the wiring dummy
1) Are the stock connectors H10's or H11's?
2) Does the stock circuit give enough power to run these according to KC's suggestion?
Your stock circuit will run those just fine. Sorry I don't know the connector designation.
Thank you for the reply! Digging through this forum, it seems that they theoretically draw less current than the stock fog lights would, but I know you have to keep the amps in consideration.
Really trying to keep it clean and use the stock button on the dash and not run a bunch of extra wiring through the engine bay. Already hate the look of my amp power cable coming off the battery :ROFLMAO:
So you are removing the factory fog lights correct? If so then you should be fine. You cannot however ADD these in addition to the factory fog lights on the same circuit.
Correct. I ditched the stock bumper and lights. Just have to weld tabs on to my new setup
Yea you'll be fine. Im fairly certain they are h10s. (They are on my 2009).
