1998 xlt 4x4 manual. When key is on position get all idiot lights everything is good, as soon as you turn to start it blows #5 ignition/starter 50A fuse. Starter will not engage. In trouble-shooting I have changed 50A fuse, Starter relay, Clutch pedal switch(it was bad anyway), ignition switch under dash, and of course starter/solenoid. It will push start fine(manual Trans) and if I run a wire from positive on battery to solenoid w/ key in on position turns-over and starts???? Where do I go from here?
