Ford may be able to get a key for you from their records of the vin. A locksmith may be able to simply make one from the existing lock. Once you have two keys cut to fit that have PATS chips, you can program them yourself using Forscan.
Ford make be able to cut you 2 new keys from the VIN Code, bring registration and ID with you, they ask sometimes
But you still need the new keys added to the PATS memory, so you can start the engine
Mobile locksmiths can do that, or you can tow it to Ford or a Locksmith
Yes you can get Forscan software and add the new keys yourself
Thanks. I had a mobile locksmith come out and make me two new transponder keys. Cost me $200 but it's done but that's the expertise of knowing. What I've seen a couple people do on youtube is mount one of the transponder keys firmly inside the steering column next to the ignition and use spare keys from now on.
Interesting. I don't remember having the option to add without clearing in Forscan, but I wasn't really looking for that ability.
To add more confusion, if you have cloned key you cannot use those keys to add a third without a scanner as the pcm sees them as one single key.
