That.1.guy
going to be doing a turbo swap soon and was wanting to know the best efi to run its a 83 that came with the 2.0.
I believe significant work needs to be done to make the intake ports match up better before factory 2.3 EFI on the 2.0 would be a working thing, and other concerns. I would second the suggestion to just swap the whole engine unless you want to pick up where I left off.
I may be misreading this, but it doesn't appear to me that the OP wanted to use the 2.0 engine, just convert to EFI and install a 2.3 turbo.
That may be the question that is being asked, but sometimes the answer to the question asked isn't the right answer to the problem.
He asked for the best EFI setup to run with a turbo swap. In this case the correct answer is to ditch the 2.0 completely and find a 2.3T that already has the right guts.
