hoosiercheetah
- Mar 5, 2010
1994, 2.3L, 138,000 mi. Manual transmission. I just did plugs, wires, air filter, and oil change a few weeks ago. I only drive about 10 miles a day.
This started about a week ago, when we had really cold temperatures.
Engine starts fine. Well, she struggles a little if it's well below freezing. But otherwise starts fine.
While running, the engine sometimes looses power. When it does this, the sound of the engine changes. I think that the rpm does not drop off, although because the power is weak, the engine and truck decelerate. When it happens, the tone of the engine drops low, as if I had shifted up too early and the engine is bogged down. But it's not quite the same as that. It's hard to describe. It will continue to run. It doesn't feel rough or choppy, just lower sound and loss of power.
Sometimes it will do it while the truck is idling. When this happens, it will almost stall out, but so far it hasn't cause the engine to stop.
Based on what little I know, it feels like an ignition problem. Maybe one of the coil packs is failing, so that I'm intermittently losing a row of plugs? Or maybe some kind of ignition module problem? I'm just guessing. I think it's not fuel, because it does continue to run when it's loosing power.
Any help that anyone can offer would be greatly appreciated.
