Blown
- Dec 6, 2007
I am sure some of you V8 guys have built-up some good power numbers as well as Turbo and Blown rigs. I hope this will help answer questions for builders. I have been researching to see if my rig would hold-up to 10lbs of boost with a rebuild, heads, cam and headers..............265hp/300ftlbs.
I am curious of what kind of power is being run through what? Please, anyone who is running more than average post-up your running gear and any problems you have had. Here is a format to cut-n-paste and I will go first.
Engine/Power:........................ Blown 4.0SOHC/207hp/250ftlbs too ground
Transmission(clutch)/T-case:.... 5R55E/Dana28
Front axle/Rear Axle:.............. Stock/"X" 8.8
Tire size/Gearing:................... 255/70-16/3.73
Driveshaft mods:................... Custom for t-case swap, no stronger than stock
No problems to date with only 6lbs of boost.
