GoletaKid
- May 28, 2016
HELP!
Hello, I'm a new member here looking for your words of wisdom about my potential purchase of a 1985 Bronco II. 4WD. 2.8L AOD
The seller is asking $3,500.00
The Bronco is an original CA car and completely original. I test drove it today. Ran very well. Has AOD trans. Owner has done a lot of maintenance. Belts, hoses, lifters, freeze plugs, water pump and radiator. Every thing electrical works right down to the cruise control. Although, why would someone replace the lifters and freeze plugs? Maybe it sat for a long time?
It did just pass smog check.
First question is: What should I keep in mind or look for before I purchase? Should I walk away? Looks too good to be true?
Second question: I have an old pop-up camper trailer. Installing a trans cooler probably a good idea? Should I tow my pop-up with the Bronco II at all?
Photos are to show condition to gauge worth.
