toyopnoy
Hello everyone my name is Pat and this is my first post here. Been a long time home garage mechanic but this is my first Ford. It's a 96 Ranger 4.0 with 200,000 miles. Do not know much history on the vehicle but it runs well and just passed smog without problems. Have daily driven it for the past week on fairly long trips in traffic with the AC on and have no signs of overheating or coolant overflow. I am not losing coolant but do have a small leaks that run down both the driver and passenger side of the block. I changed the spark plugs and wires a few days ago and noticed the leaks running down the side of the block. Did an oil change recently and there is no sign of coolant mixing with the oil. Did a coolant flush and there is no sign of milk shake (oil mixing with coolant) in the radiator. I have searched the forums and found some possible culprits lower intake gasket leak, headgasket leak, or cracked/warped heads. Any insight is greatly appreciated, thanks in advance. Here are some photos to help illustrate:
-Passenger Side view through wheel well. Leak stains running under header.
-Driver side view from the top. Bad photo but there is also some coolant leaking down the side of the block that drips onto the front crossmember.
-Underneath the truck on the passenger side. Coolant dripping down the side of the block onto the cooler lines and oil filter area.
