edward2016
- Jul 1, 2014
- Texas
- My credo
- do what you do and do it well
earlier i tired bleeding the slave cylinder. did that correctly to find out i now have a very soft clutch. starts but wont go into gear. goes into gear fine with the truck off. i've tried to take apart this master cylinder mechanism inside the cab behind the pedal. something about getting the snap ring off the piston to relieve the air bubbles inside the master cylinder and it will then work. i just need help getting this snap ring off and if any body has any suggestion to a soft pedal fix
