No brake lights, running or dash lights
kevinbmx77
None of my lights are working except the headlights, if i balance the headlight switch perfect it will all come on and work till i hit a bump. Its a 1994 ranger xlt single cab. The abs light also started blinking during all of this and i cant figure it out, i checked the fuses and all of them. I need the truck but cant drive without brake lights
Sent from my SM-G920P using Tapatalk
did you check the obvious Bulbs, wiring grounds etc...
also if you have trailer wiring check that as well
check head light switch as well
The trailer wires were all messed up and i found a blown fuse, all works now
SEARCH! lol Fuses are good, need to check wiring and headlight switch on 2003, 3.0.
