interchangable hoods?
across281
I hit a deer with my 03 edge and I am wondering if hoods from a 93+ ranger/explorer or even 2000s that is not an edge will swap over. I am pretty much trying to repair this as cheap as possible with any parts that will fit. I am located in houston tx in case anyone wants to sell their stuff.
I had a 96 hood (fiberglass) for sale and it would, apparently, fit all the way up to 2011...it was the flat style with no nostrils built into it like some of the fancy ones...but I think those are aftermarket...
You can check LMC catalogue to cross reference parts...if you don't get a definitive answer...or there is the thread where we are building the parts interchangeable list...
http://www.therangerstation.com/forums/showthread.php?t=68672
That is actually nested under the Submit Info For Tech Articles if you want to navigate back to it some time...
http://www.therangerstation.com/forums/forumdisplay.php?f=5
New Here and first post, my 98 ranger rolled into a tree, Not a mechanic but i would like to do myself, I guess I need everything up front, grill, bumper head light assemble,. so please tell me what year can i interchange with on the front clip, I suppose I need to change the whole front clip and The hood any advice would be appreciated.
--------------------------------------------------------------------------------I hit a deer with my 03 edge and I am wondering if hoods from a 93+ ranger/explorer or even 2000s that is not an edge will swap over. I am pretty much trying to repair this as cheap as possible with any parts that will fit. I am located in houston tx in case anyone wants to sell their stuff.
93-97, 98-03, 04-11 = those years use the same fenders, hood, radiator support, header panel, & bumpers. So you can put an older frontend on your 98 up as long as you change everythin I listed above, and visa versa (98 up can be put on a 97 back by changin those items).
does that also go for explorer front ends onto rangers and visa versa
