Pdunkk
- May 14, 2015
Well first and foremost im about to run this truck into a lake.
https://www.youtube.com/watch?v=tPWVrQvnI2k
So currently this is what my truck is doing, It's a 1998 Ford Ranger 2.5l 4Cyl Manual Trans.
Things i've done so far is new IAC, fuel pump, fuel filter, spark plugs (all 8), water pump. Cleaned the EGR, and MAF, and it's still not getting any better.
I replaced my timing belt back in Nov 2012, and it's been running fine since this incident which happened back in November of last year, I pulled a Uhaul filled with appliances for maybe 5-10 miles then my truck wasn't having it anymore, it started bucking really bad, and I couldn't drive it. Over the course of the last week, I've been trying to set the timing, and finally got everything lined up today. The video is what its doing since I put the timing back in time. It may even be off a little, but im pretty sure it's not. but 1 tooth is 1 tooth, and it's the most tedious task.
So any insight on to what could actually fix this thing, would be greatly helpful.
Thanks dudes
Thanks dudes
