Just saw this, looks like you're getting somewhere! On the airbox, look at mine, I think I posted a pic in one of your posts, it's a simple setup that I did with junkyard parts, you might be able to do it with your stock leftovers...
I have to say that it looks like you took my advice and went with it, with less detailed instructions than most people take, so you're above average in the mechanically inclined aspect, it looks good and I'm sure you'll be happy with the results, I know my truck would be a DOG with the stock engine with it's current setup, but now you punch it and it just flat goes... bit of turbo lag but hey...
Have any issues with my instructions on the crank sensor mounting? Did you have to extend the coil pack bracket like I did?
It's just a 12 point 12mm socket or you can even use a 12 point 12mm box end wrench for the drive shaft bolts. I use a 12 point 12mm Snap On impact 3/8'' drive wobble socket so I can use my impact on the bolts. For a one time deal the box end wrench would probably be the cheapest way for you to go.
Yeah, those darn bolts really threw me for a loop. I tried some of my sockets and they didn't fit...(six point of course) so I assumed they were "special" ones that needed "special wrenches.Looking good in there. It's nice to have the hard work done and be onto the fun stuff. I like the Turbo Coupe valve cover. I put one on my 2.3L Mustang and was thinking about putting on on my Ranger until I removed the stock steel valve cover and saw how tight of a fit it is in my 97 getting the valve cover off and on. I was worried the thicker aluminum cover just wouldn't fit with the 97 upper intake and EGR tube.
It's kind of strange that Ford started using 12 point nuts and bolts instead of 6 point. The older 2.3Ls have 12 point head bolts and carb. mounting nuts.
