Fuel pressure does not decrease at cruise or any other condition on a fuel injected engine while its running, if it does you have a pump or regulator issue.
As for higher pressure, on a correctly functioning injector it can actually cause them to hang a bit in their cycle and cause a poor spray pattern. Same situation with a weak pump, which can be failing in pressure or volume & will cause very poor spray patterns on injectors. I am not saying you cant raise rail pressure, just if you do you almost need a flow / spray pattern bench to see the results.
Higher psi pumps, or more importantly pumps that have higher volume capabilities for higher horsepower applications is what I believe the OP is looking for. Is there a Taurus upgrade, I dont know for sure, but since Ford put the 24v Duratec in some Taurus's they may have upgraded the pump, will it directly bolt into your tank? again not sure. Might be worth a look into the part numbers for 3.0 vs the Duratec option.
I did a pump upgrade on my truck for the larger injectors and used a 175 walbro unit, I had to dissemble the fuel cartridge unit and replace the stock pump with the 175, while not an exact direct fit it did go together with a little re-engineering and works just fine, I normally see 58-60 psi and with a rising rate regulator, FP increases with every 2 psi of boost accordingly, so @ 18 psi of boost I see 68 - 72 psi of fuel pressure all due to demand.
Pressure alone has very little to do with A/F ratios, I have a Chevy TBI truck that has 62lb injectors in it that run at 25-28 psi & it maintains the 14.6 - 14.8 range on the wide band almost all the time except for WOT where it richens accordingly.
Diesel & Gasoline are 2 totally different animals, not only in injector pressure, but cylinder pressures and timing events due to the volatility & the compress ability of the difference in the fuels.
As for the brand of fuel pumps it has been my experience to avoid the low cost no-names, they fail pretty much just after the warranty, Delphi, Motorcraft, BG, Walbro, BK, Echlin, all seem to be good quality products from my personal experience.
JP02XLT
