6.2
- Aug 19, 2011
Alright, so when i got my new tires slapped on a few months ago i also had the truck aligned. They got it within spec, but just barely on the driver side front. they had it adjusted all the way positive, and it was barely within spec.
there were no issues aligning it last year earlier.
im pretty sure i bent something, but i honestly cant see anything out of the ordinary between the passenger side and driver side.
I need to figure this out asap so i dont kill my basically new tires in a few months. i could get camber bolts to allow furhter adjustment, but if it came out of alignment in only a month or two somethings up.
i want to fix the issue properly rather than just hide it with camber bolts.
so, my question to you ranger guru's is what do you think i could have bent. i have a bit of negative camber. as in, top of the tire sits further in than the bottom.
any way to check for bent items without just eyeballing it?
im guessing its either a lower control arm or upper? but they both look fine to me. Knuckle maybe? but again, looks fine from side to side and the passenger side tire is fine.
i drive this thing way harder than any stock truck should be driven, so im almost positive i bent something just dont know what. any help would be appreciated. ill try and snap some decent pictures later and see if that helps
