cp2295
- Jul 25, 2013
- Washougal, wa
- My credo
- If you ain't first you're last
What to use on a 99 ranger with a 4.0 ohv? Can I just use a 97 and older steering box? Also what parts am I missing from this list?
-D44 from a 78/79 bronco and ford 9".
-Coil buckets and leaf perches from both axles
-Steering box and lines (May need fabricated lines if I can't use the rangers box)
-Lengthen front driveline? Also will I need to remove that dumb cv type connection off the driveline and put in a different carrier on the t case (a ujoint style)? Or can I take the broncos front driveline and use it?
-coils and leafs from the bronco or should I use my rangers leafs and buy some different coils? Any recommendations on coils?
-what shocks should I use?
-will I need to modify the rear carrier to accept my rear driveshaft?
-37x12.5x15 and recommendations on tire?
I want to get my ranger to clear 37s with relative ease, but not much, so would 6" or 8" of lift off stock height where it sits right now clear those tires pretty good?
I can get a complete front axle for $175 including the knuckles and without the hubs and brakes which I don't care about, would want new ones anyways.
The rear I can get for $85 complete minus brakes again.. So this swap is looking pretty affordable (minus the tires!)
So if anybody's done the swap let me know what I'm missing, I've looked at quite a few forums and I got the jist of it all but still a little unclear about everything that I'll need.
Another thing that's making me want to do this swap is the cv joint is starting to click on the driver side so it's time!!
