Sabai
- Jan 22, 2014
Hello! I've wanted to buy a Bronco II and finally found a really nice '86, from a poster on this board in fact (username Sultan). I told him I'd post updates and pictures here, I will try to keep the rig an active member.
Would appreciate some help troubleshooting an issue with the radio. It has the "Premium Sound" option, and Eddie Bauer.
I was told "radio doesn't work". It had a blown fuse. Display/clock was black even after I put in new fuse. Rear speakers worked only intermittently.
I took off the dash fascia, pulled out the radio, replaced the bulb (72LL 1.1W) this was not too difficult. Now the display works. The wires in there looked ok to me.
I inspected the separate amp under the dash (removed the cover and pulled it out), looks fine. Apparently this amp powers the rear speakers.
Put everything together and the rear speakers worked for about 10 minutes (indeed it was a premium sound), then went dead. The left front speaker went dead too.
Later same day all four speakers were working again. Then the rear died. Now both front work.
Based on this, does it sound like the stereo unit itself is the culprit or must it be wiring?
Thanks for any advice!
