dieseldane
Firefighter
EMT / Paramedic
- Aug 28, 2009
- Garnett, KS
- My credo
- If it doesn't fit, force it!
Was browsing the Ford Racing catalog earlier and noticed these, but hadn't ever heard of them mentioned before, and a search didn't show anything either. I wonder how they would fit in an RBV?
The Description in the catalog:
STREET ROD HEADER
M-9430-SR302
• Put a Ford in your Ford with this compact
4-into-1 clamshell-design street rod header
• Fits most 289/302/351W applications
• Jet-Hot® ceramic-coated 409 stainless steel.
Stain and rust resistant. Limited Warranty
• 1-5/8" primary tubes with 2-1/4" ball-style collector
for easy exhaust pipe connection
• Includes short outlet pipes with 02
sensor fittings
• Will also fit GT-40P heads
• Designed for maximum clearance in the narrow
frames of early Fords
• Machined flange
• Bolts to stock exhaust pipes
• Includes gaskets, bolts and studs
• Designed by Ford Racing engineers
• Finest short-tube headers
you can buy
• 164-tooth flywheel applications
may require aftermarket starter
Jeg's listing:http://www.jegs.com/i/Ford-Racing/397/M-9430-SR302/10002/-1
STREET ROD HEADER
M-9430-SR302
sensor fittings
• Machined flange
you can buy
