mephiska
- Mar 13, 2011
So I have a bit of a dilemma. This is probably a question many of you have pondered in the past - do I keep spending money on my truck or do I sell it and get something newer and more reliable?
TL;DR - I've dumped a bunch into a 1994 Ranger - do I keep going or sell it now and spend more on a newer truck?
At this point I've dropped couple thousand into maintaining and upgrading my 1994 Mazda B3000 w/160k miles. I bought it about three years ago for $2400. Right off the bat I had to put new tires on it, replace the front brake pads, passenger side wheel bearing and put new monroe sensa-trac load sensing shocks on it. That fixed the awful steering wheel shake I was getting at freeway speeds and made it drive pretty nice for a nearly 20 year old truck. It now rides quite nice on the freeway.
Since then, mechanically speaking, I've had the rear brakes redone, rear bearing, A/C repaired (leaking valves, works great now), transmission flushed and filter replaced, fuel filler hose replaced to pass smog, coolant system flushed, and that's about it. I still have a problem with the coolant sensor not registering correct temperature, or the truck isn't heating up to the right temp under operation. I haven't figured this one out yet.
Lastly, on a recent trip, at the worst possible time (July 4th), the front seal blew on the A4LD and I had to get towed. Luckilly I found a transmission shop that was open and they fixed it the next day, also replacing the torque converter with a rebuild since that was worn out.
As you can see I've done a lot to this thing. Outside of mechanical stuff it was filthy on the inside, so I took my Bissel steam cleaner to the interior, which made a dramatic improvement (brown seats turned grey, yeck!). It's clean inside, comfortable, the A/C works and after a basic radio swap it works with my iPhone. It's the extended cab model with the long bed, 2WD, and pretty much suits my needs.
I figure at this point, outside of something catastrophic with the motor, everything on this truck should be pretty solid for a while.
Now that said, I've priced new/newer trucks. They're not cheap. The cheapest small truck on the market in the US looks to be a Nissan Fronteir at around $20k+. Used trucks aren't much better with mid-high mileage models from 2-4 years old selling for $16-$18k. Hell, look at this 2011 Ranger for $20k!
I could go lower but my impression of the used truck market is there's basically a baseline price for a working truck. And I know once I start going down that scale I'm going to have many new problems and ultimately end up right where I am now, with a truck that needs an unknown amount of work. And at this point I've already spent the time, money & effort to get this one up to proper running condition.
So, what do you fine folks here think? Would I be better off biting the bullet, selling this one and getting something newer, spending the cash upfront or keep this one that I've already put effort into?
