Wiring heated lumbar seats from 2005 Explorer Sport Trac
Vamirr
Hey guys,
I'm running into an issue as I'm wiring these explorer seats in my ranger.
The wiring harness seems to work like this:
Green - motors (power always on)
Yellow/Light Green - heated seats (power to swiched)
Red/Black - heated seat switch light (power to switched)
Black - ground
Yellow/Grey - ????
I'm not sure what the yellow/grey wire does. It's not present on the passenger side. On the driver side, it switches a relay.
Any ideas?
Grey and yellow is power into the coil for the heated seat relay.
This driver's seat is driving me nuts.
Here's how I've got things wired right now:
Yellow/Grey - seat relay coil (switched power)
Yellow/Light Green (larger gauge) - heated seats (swiched power)
Red/Black - heated seat switch light (switched power)
Black - ground
When the truck is off, the motors work, the switch lights and heated seats don't; everything is normal.
When the truck is on, the motors work, the switch lights and the heated seats work; everything is normal.
When I turn the truck back off, everything still works. switch lights and heated seats included. I have to kill the power at the battery for everything to reset again.
If I disconnect the seat relay wire, everything seems to operate as expected. So what is that thing doing? How is it supposed to be wired if not to switched power?
