So I just replaced the heads and head gaskets on my 91 4.0 ranger. Started fine properly bled the cooling system now the idle surges slightly a few hundred rpm at most and temp gauge doesn't go past the o on the normal on the temp gauge. It got up to m once and went back down. Normally rests on n with a slight fluctuation up to r then back to n I put a new thermostat in as well. No air in the cooling system heat it great upper and lower rad hoses are hot along with heater core hoses.
Any ideas?
Any ideas?
