huey
My dad has a 92 ranger 3.0 automatic. one day it started gushing fluid out of the front seal! had it towed home started and drove it into the garage pulled fine no problem. took it to a trans shop they replaced the front converter race (thats what they called it). said it was common. I also installed a NEW tourqe converter as recommended (filled the tourqe with 2.5 qts of fluid and made sure it set back 3 times while spinning) put it all back in with new trans filter. filled with fluid turned the key let it run for a few min and circulate the fluid. atleast I thought it was. the Pump isn't working!!! u can let it run forever and the fluid will never move off the stick or get warn u can take a line off the coller and nothing! anybody have any suggestions? Please no smart comments!!!
