Dana 35 Axle Shaft Spacer
zman7125
10+ Year Member
Buffalo, NY
Does anyone know where I can find these? Need one for my '97 STX which is missing it on the passenger side.
Are you talking about the one that goes between the c-clip and the spindle out by the end of the stub shaft?
Yes sir
My apologies I haven't put my signature up or my picture I'm on my phone, once I get on my computer I will bring my info over from other Ranger forums. Hate it when people post without any info haha
JY is gonna be your best bet. broncograveyard.com might have them too.
Local yard said they're not gonna pull apart an axle for a washer. Called my Ford Dealer though, strangely enough they have a couple on hand. Told him I'd stop by with an exploded view to double check that we're talking about the same part and if so, get a couple. Figured might as well have some on hand in case any one else on here needs them as they seem to be misplaced a lot and are hard to come by.
As I see here in this exploded view, I should be able to just pull off the wheel, the hub, then the snap ring, place that washer in front of the bearing then replace everything in that order, correct?
Thanks for your guys help, only been on this forum a couple times but DAMN there is so much info. I spent hours in the "Tech Library" section last night reading, awesome!
Dana 35 Hub/ Spindle Assembly
if the stealership wants too much, lmc truck will have it
edit-accidently posted the page for the d28 first
Looks like on the Dana 35 drawing its not listed, but on the 28 it is. At least from what I can see, what part # is it? It looks greyed out here I thought it was in between the spindle nut & snap ring?
i got mine at ford. relatively good price for the stealership
yeah, i'm just seeing this now. my bad, i was thinking you were looking for a different part.
No worries appreciate the effort, I have a couple LMC catalogs at home and had the same problem, i was thinking maybe I'm just not seeing it. Strange they have it for the Dana 28 but not 35
Okay, I guess NAPA carries the part as well.
Still no part number has been posted....
