previous owner took off my egr???
gregorys1989
So ive been told to check my egr for the cause of my bad idle. Ive been looking for sometime and could not seem to find it. So i referred to one of the diagrams Chilton has for the egr setup. It is gone, the previous owner has the egr caped off in each spot it hooks up. The intake has a piece of metal over it with bolts holding it down. Should I just go to the scrap yard for something like this or is there somewhere i can get the whole set up for cheap?
from my understanding there is a hose that goes from the exhaust manifold to the intake manifold with the egr connected to the intake on the driver side of my vehicle. I can see the obvious spots where it is supposed to be, but yet it is not there. Who's bright idea was this that said "ohh i dont need that". Sad to say butt i almost find this funny.
Why is it in the chilton diagram then for my year, and engine size? im confused here.
Sorry to inform you, but the 93 & older 3.0's in the Ranger never had any kind of EGR setup on them. Your 92 never had that on there.
Actually, I thought 93 Autos had an EGR, MT did not. Not sure if that extended any further back than 93 or not.
I have a '93 and I've definitly got an EGR setup, went trolling around a junkyard the other day for the cover plate and screw for the EGR valve I just put in, but apparently every other Ranger except mine has an EGR Valve without that useless hole in it.
The other thing is that I believe California Emissions models might have had EGRs. Do you have any plugs disconnected around the Intake? If not, it's possible someone put a new ECU in that had Cali emissions.
Yeah i have one plug that is disconnected on the passenger side by the intake manifold. its more towards the distributer if that helps any. elaborate a little though please, what is an ecu? does that replace a egr? Im almost certain the truck is originally from new mexico.
ECU = Engine Computer. Can you take a pic of the plug or describe it (number of pins, color of wires coming off, etc.)
These are the best pics i could come up with. the wire has two red leads with what looks like some kind of cap on the conecter. The other pic is a pic of my intake manifold where the egr is intended to be. The other pic is what is what i think is my "exhaust manifold" , driver side, where the egr is intended to take the exhaust from. Fealing around on this piece i see no cap off device or screw holes. so im not sure whats going on here. Please any help would be really appreciated
just realized the third pic on the attachments "the two lead red wire" i was talking about. u cannot see. It pretty much lays on top of the valve cover. dont know what its for. it has a black base and that grey cap covering the connectors inside. I have yet to remove this grey cap because i have no idea what it goes to. In the California emissions, what do they use in place of a egr?
Thats not a cap, its either the SPOUT connector or the octane adjust shorting bar. (I'm not sure which one from the pic, they both look the same.) It has nothing to do with the EGR, leave it alone.
The presences of the block off plates does not mean that an EGR was there originally. EGR and Non-EGR applications use the same intakes; Non-EGR simply have the block off plate as you do. There is no knowledge to be gained from its presence alone.
The lack of an EGR port on the Exhaust Manifold highly suggests that your truck did not have EGR at all. Yes, it's possible that someone swapped a non-EGR manifold on, but it would've been easier to simply cap it off.
Do you have an AT or MT? I think you're chasing a ghost here. You would have at least two unused connectors, one for the EGR Position Sensor and one for the DPFE.
auto and yes i agree about the chasing a ghost deal. Im going to purchase a proper code scanner with a digital readout "only 35 bucks" and see what that pulls up. ill post them here. thanks for the help
