Wheels, Brakes & Steering
DISCLAIMER: Activities and vehicle modifications appearing or described at The Ranger Station and it’s pages may be potentially dangerous. We do not endorse any such activity for others or recommend it to any particular person – we simply describe the experiences and opinions of other Ranger/Bronco II owners. If you choose to engage in these activities it is by your own free will and at your own risk. Any and all modifications will likely cause a vehicle to behave differently than stock. Some modifications may significantly increase your risk when driving the vehicle or be dangerous in some driving situations. Use good judgment when engaging in any activity or making any modifications. Do not take unwise risks. Consult a certified professional if you are not sure of something. The Ranger Station and the authors of these articles assume no liability for how any particular individual chooses to use the information presented here. Some of these modifications may void your vehicles warranty. Please also read our Legal notice HERE.
Desktop Site:
Check out the desktop version of our Tech Library for a full site version of our articles.
Stock Specifications:
If you’re looking for stock specifications, or trying to figure out what your Ford Ranger came with, CLICK HERE.
Tires & Wheels
Choosing A 33-Inch Mud Terrain
Choosing A 35-Inch Mud Terrain
Buying Used Tires
Ranger Wheel Guide
Mustang Wheels On Your Ford Ranger
Tire Fitment
Tire Load Ratings
Trailer Tire Wear
Brakes
Trouble Shooting
Brake Upgrades
Mustang Rear Discs For Your Ranger
Sport Trac 12-Inch Rotors For Your Ranger
Relocating Brake Lines – Front
F-350 Brake Line Upgrade
Replacement Extended Rubber Brake Hoses
Disc Brakes For Your Ford 8.8
Dana 44 Disc Brake Conversion
Explorer Rear Disc Brake Conversion
EBC Brake Upgrade
Steering
Trouble Shooting
Vacuum Bleeding A Ford Power Steering Pump
AGR Power Steering Pump
Saginaw Power Steering Pump Swap
Hydro Steering – Box Tap
Installing Full Hydro Steering
Ford Steering Box Rebuild
Steering Tech – TTB Steering & Alignment
Ford Steering Box Mild Rebuild
Front End Wheel Alignment
Steering Intermediate Shaft Wear
Steering Shaft Rag Joint Replacement
2WD Turning Radius Correction
Camber Bushings
Make A Ball Joint Tool & Replacing Ball Joints
Ball Joint Install
Sway Bar Bushing Replacement
Exploded Views
1998 Brake Hub Assembly
2000 Front Disc Brakes
Calculators
Convert Metric Tire Sizes To Inches
Speed Change From Tire Size Change Calculator
Check Speedometer Change After Tire Size Change
